Industrial Communications
NI-Industrial Communications for EtherNet/IP communication with NI Vision Builder AI
I have been trying to run an ethernetIP server (using vision builder AI  [VBAI]) along with the NI-Industrial Communications for EtherNet/IP VIs to talk to it. Unfortunately I am not successful and I am getting the CIP Status 0x5:
Error: -251723760
EthernetIP Tag Read STRING.vi;
Details: CIP Error - Extended status may be available
CIP Status: 0x5 (Invalid destination/class/instance/structure)
I would love to know what I am doing wrong.
FYI: I have tried to read other registers (that the one in the red box) with the same result. I must be overlooking something obvious here.
See the image below that describe my settings and the error:
(3,256 Views)
The standard format of the Network Path is "*.*.*.*,*,*". So you can try to change the Network Path to 192.168.63.176,1,0.
Thanks!
(3,247 Views)
