Industrial Communications
ProfiBus as an application (.exe)
Hi Friends,
I'm working on different industrial communication interfaces, one of which is ProfiBus, when I try to run the code in a development module the code works fine and when I try to run as an executable the particular test sequence with the ProfiBus configuration failed.. I'm not sure what is the dll that is used to interface with the  system. Can someone suggest me some solutions?
Message 1 of 1
(5,386 Views)
