10-10-2013 05:22 AM
10-29-2013 09:19 AM
Hi Shreyas,
I have no ideas on what the root cause is based on your description, but the blue outline means that the slave is online but has diagnostic data. You should be able to double click on the icon and it will bring up a dialog with a "diagnostic" tab. That tab can be used with the Synamics manual to look up an error message.
