Industrial Communications
Profibus with CompactRIO
Is it possible to use Profibus protocol on Compact Rio Hardware ?
(11,914 Views)
What exactly do you need? Profibus slave or Profibus master?
A Profibus slave module is already available from Dataahead. If you need Profibus master functionality you should contact Comsoft. They are currently in the development process for a Profibus master/slave module and they should be able to give you a forecast when the module will be available.
Jochen Klier
National Instruments Germany
Message Edited by Jochen on 04-02-2007 03:44 PM
(11,909 Views)
Thanks for your answer,
I don't know if I need "Slave" or "marster", I have just to send a data to a PLC.
I don't speak German and the DATA AHEAD web site is only in German.
Best Regards
(11,904 Views)
In this case the PLC is probably acting as master so a slave module should be ok. You still should verify this. If you want to contact Dataahead please email to info@dataahead.de.
Jochen Klier
Message Edited by Jochen on 04-02-2007 04:59 PM
(11,899 Views)
Thank you Jochen, I contact Dataahead today.
Best Regards
Kerv
(11,894 Views)
