11-06-2019 05:15 AM
HI,
I am using cRIO profibus module to communicate with profibus PA device using pepplers + fuchs coupler. In configurator i am getting this message when i try to download configuration. Also i am not able to add modules as this popup says.
02-27-2020 01:36 PM
You need to add a module. Right click inside of the white space below the device block. In the area that says slot 1, 2,3 and select add module.
