Industrial Communications
Profinet and LabView
Hi all,
I need to drive a Siemens variator from LabView Windows or LabView RT, i don't know yet the needs of my customer in terms of determinism.
So I guess Labview will be the profinet master on the bus.
Can I use a standard ethernet port to implement this master ? Or do I have to you a specific board like Comsoft ?
Is there any library or toolkit which implements profinet on standard ethernet port with LAbVIEW ?
Thanks for your help !!!
(8,292 Views)
Profinet requires deterministic timing and onboard CPU power to run the protocol. Profibus/Profinet National Instruments cooperates with Comsoft and they should have a Profinet board with good LabVIEW integration available.
Please contact Comsoft for further information.
Regards
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(8,236 Views)
I found out about this dll, that allow to connect without further hardware, are you familiar with it?
(6,795 Views)
