Industrial Communications
Reading a Logix500 Tag that has a Scope limited to a Tasks (not global)
We have a Rockwell PLC (RS 5000) that has multiple tasks (seen in S02). Each task has scores of tags defined.
We can read Global Tags (shown in S00) but we are not able to read tags that are scope limited to a task (shown in S01). We get CIP error code 0x04 .CIP Error Codes
We are using LabVIEW 2021 and the code is using EIP Industrial Communication SubVIs to connect with the PLC. We believe the tag names have to be formatted certain way for tags that are not global for the EIP driver to work and fetch the data correctly. Can some one give us a hint how to format it to work?
(279 Views)
we posted a similar question at the following link with the screenshot of LV Code.
Addressing Local Tags by EIP Client - RSLogix 5000 - Allen Bradley / Rockwell Automation - Forums.Mr...
(250 Views)
