05-10-2010 03:58 PM
Hi all...
I have an application written in labview and i want that front panel is published on the web but i dont want install a labview on the target machine.
The PC acquire H24 with this application i create an executale, installed run-time engine and the pc Acquire. I want publish the front panl on the web can you help me??
tank you very much...
05-11-2010 02:28 AM
Loopin3,
for this task you can use the native "Remote From Panel" feature in LabVIEW. Here are some hints you should keep in mind when using this feature.
General hint: The industrial communication forum ist meant to be used for questions about field busses (Profibus, CAN, Ethercat,...). Your question is much more related to LabVIEW, so it would have been better to post it to the LabVIEW forum, as there are much more community members actively monitoring this board.
Kind regards,
Jochen Klier
