Industrial Communications
Robox EtherCAT Slave PDOs not getting completely loaded from XML File
Dear All,
I am testing a Robox EtherCAT S120 drive module with CompactRIO 9047.
The slave can't start to the operation mode. From the logging file, looks the Master is writing the wrong address. The ESI file is attached here.  Hope to get your support soon. Thanks
(2,636 Views)
did you solve the problem? I have the same one.
(2,266 Views)
Hi All,
same issue here.
Every advice It will be usefull.
All teh Best
Golzio
(2,206 Views)
