Industrial Communications
Simple DNET set output fail on error: wait for state
1. I’ve configured correctly  the device net as seen in MaxDnet.png.
2. It is also detected correctly as seen in
MAXConfig.png & GetDeviceList.png (by using DNET example GetDeviceList.vi).
3. But, when i use an example in labview to set 1 output as seen in DeviceNetErr.png. Showing “wait for state” 1074388912. It seems that i dont know how to set input length & output length. Where can i get those information?
Message 1 of 20
(12,323 Views)
IF YOU CAN'T ANSWER AT LEAST GIVE ME DIRECTION WHERE TO LOOK FOR HELP????
NO PHONE SUPPORT FOR DEVICE NET FROM NI......
IF I HAVE EDS FILE FROM OMRON, DOES IT HELP???
I'VE TRIED UPLOAD & DOWNLOAD EDS FILE FROM USING EDS MANAGER...
BUT IT DOESNT SOLVE THE PROBLEM????
ANYBODY CAN HELP????
Message 2 of 20
(12,301 Views)
Sorry, we missed this request somehow.
It would be helpful to know what you are trying to do. Your screenshot shows that you indend to use 8 Byte Input and 8 Byte Output in a polled connection.
But there is no output data configured. Could you please try to configure your Output array to have 8 byte of valid data  and then run the VI again?
DirkW
Message 3 of 20
(12,295 Views)
1. When I want to configure using configurator (using protocol DNET), it always shows EDS error as shown in
EDSAlwaysErr.png.
2. Although i have download the EDS of the OMRON as shown in AlthoughEDSSuccess.png.
3. Even after i refresh the list.
4. So, how to configure? and where can i configure?
I am just guessing here, the manual is not clear.
What i want to do is just to do a simple testing to turn one bit on and off.
The code i am using is from the example provided by NI.
Message 4 of 20
(12,293 Views)
CAN anybody help me how to work with DNET???
thanks
Message 5 of 20
(12,280 Views)
please help me with my questions
Message 6 of 20
(12,279 Views)
Could you post your EDS file and describe in detail what you want to accomplish?
Thanks DirkW
Message 7 of 20
(12,274 Views)
Regarding the missing EDS file, your devices firmware might be different from the one specified in the EDS file.
Can you find out the Firmware Revision used by your device?
DirkW
Message 8 of 20
(12,273 Views)
hi Dirk,
This is the EDS file. Does it tell you anything?
Message 9 of 20
(12,271 Views)
Dirk,
1. do you really know how to use / configure your own software??/ this is NI software!!!!
2. how can you ask me again and again describe what i am doing, while i 've written 2 times, i just want to test to turn on & off 1 bit (output)
 isnt this clear enough??? i am a newbie, dont even know how to configure using your software.....
YOU KEEP ASKING AGAIN & AGAIN WHAT I AM DOING....
3. ALL SCREEN SHOTS ARE GIVEN TO YOU, BUT NO SOLUTION SO FAR...
4. I'VE CALLED OMRON, THEY SAID THEY EVEN WANT TO BE IN A CONFERENCE CALL. THE OMRON MODULE WORKS FINE. YOU KEEP REPLYING EMAIL WITHOUT ANY SOLUTION.....
5. IF YOU DONT KNOW HOW TO CONFIGURE, ASK YOUR BOSS!!!! DONT REPLY 1 EMAIL PER DAY.
DONT YOU KNOW I AM GOING TO COMMISSION THE PROJET DURING CHRISTMAS!!!!!
6. YOU WORK VERY SLOW!!!!
6.A. GIVE ME AN EXAMPLE HOW TO CONFIGURE (CONFIGURATOR IN MAX)
6.B. I USE YOUR OWN EXAMPLE SINGLEDEVICE.VI....
ISNT THAT ENOUGH TO TELL WHAT I AM TRYING TO DO????
Message 10 of 20
(12,268 Views)
