Industrial Communications
TCP/IP Error 60 problem
Hi.
i have problem with TCP/IP Connection error 60.
Product TCP is server, PC is Slave.
Error 60 is occured when the corresponding port is in use during TCP or UDP connection.
I looked at the Labview code to see if the problem was caused by not closing TCP/IP properly,
but I could not find any problems in the code.
then, i checked whether Windows is actually using the port, but the port is not in use.
i checked with CMD Prompt - Netstat
The biggist problem is than it can not resolved untill PC reboot.
any advice would be appreciated.
thank you
Message 1 of 1
(1,897 Views)
