Industrial Communications
TDMS-Specification
Hi all,
I have a problem with the specification of the .tdms file format. (https://www.ni.com/en/support/documentation/supplemental/07/tdms-file-format-internal-structure.html).
Here is a snippet of a example file i have. This file is validated, so it is specification conform. But some things i don't understand.
54 44 53 6D                                 // TDSm -Tag
0A 00 00 00                                 // ToC-Mask (MetaData und RawData)
68 12 00 00                                 // version Number (4712)
58 00 00 00
00 00 00 00                                 // Next Segment Offset (88)
3D 00 00 00
00 00 00 00                                // Raw Data Offset (61)
01 00 00 00                                // Number of Objects (1)
15 00 00 00                                // Pfadlänge (21)
2F 27 54 69
6D 65 73 74
61 6D 70 27
2F 27 45 76
65 6E 74 73
27                                                //Pfad (/’Timestamp’/’Events’)
1C 00 00 00                                // RawData Index (28)
20 00 00 00                                // Datentyp (String)
01 00 00 00                               // Array-Dimension (1)
01 00 00 00 00 00 00 00           // Number of Values(1)
1B 00 00 00 00 00 00 00          // Total Size Raw Data String (27)
00 00 00 00                              // Number of Properties (0)
17 00 00 00                              // Don’t know what this is. This value is exactly the length of
                                           the following String, but i can’t find a explaination why this value is given here.
33 34 32 32                         // I think, this is the raw data value.
30 35 34 36                         // (3422054607;FALSE;BZsave)
30 37 3B 46                        // The datatype could be a timestamp ?
41 4C 53 45
3B 42 5A 73
61 76 65
Now the next tdms-Segment. This follows directly the snippet above.
54 44 53 6D                      // TDSm
08 00 00 00                      // ToC-Mask (just RawData)
68 12 00 00                      // Version (4712)
1B 00 00 00                     // Length of the segment-Offset (27)
00 00 00 00
00 00 00 00                     // Length of the rawData Offset (0)
00 00 00 00
17 00 00 00                    // Just like above, i can’t explain why this tag is here.
                                      // Obviously this is the length of the value, which follows,
                                      // but there is no datatype? How can i know, how i should
                                      // read such segments without metadata and datatypes?
33 34 32 32                    // Here is the value:
30 35 34 36                    // (3422054623;FALSE;ES AUS)
32 33 3B 46
41 4C 53 45
3B 45 53 20
41 55 53 54
Can anybody help me with this ?
Thank you very much for your help!
(3,789 Views)
Hi brampolt!
I recommend you post this on the normal LabVIEW forum, as this page is specifically for industrial communications protocols and their drivers. You will probably get a more knowledgeable response on the LabVIEW board. If / when you do post there, please include why you want to decode the .TDMS file youself - there are libraries to parse the TDMS file format in Microsoft Excel, C / C++, The Mathworks Inc. MATLAB software, and of course, LabVIEW.
The insight I can lend is that the data is rawDataValues - which is normally unitless. For instance, you could set up a DAQmx stream to file node and it would stream the values coming off the ADC - which are not normalized, and may even need to be linearlized based on a standard algorithm and temperature factor. Therefore, "raw data" normally implies a unique data set that you must put through some algorithm in order to reach unit-ized values.
Hopefully this information was useful! Again, I recommend you post this to the LabVIEW board as you get more eyes on it.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,749 Views)
