Industrial Communications
Tcp/ip Open Connection status
I'm totally new to LV but have managed to write a TCPIP client successfully. My only problem is that once my tcp OPEN Connection VI is running, how to check it status. I need to know this as I want to use the TCP ID if already opened, else create a new connection.
Cape Town
Mogamad Amien Crombie
Senior Software Engineer,
iThemba Labs [TLABS]
Faure
Cape Town.
Western Cape,
South Africa
(7,463 Views)
Can you please explain what you mean by "check the status"? Also what module or VIs are you using to accomplish your task?
(7,446 Views)
Hi
I'm using LV 2009 with the "\Datacommunications\Protocols\TCP" palette function.
The "TCP  Open Connection" function is the one I'm enquiring.
I'm trying to rewrite a DotNet DLL with native LV. In the DLL, I create a TCP connection once. Then I create 7 classe instances using this connection.
As I can query the TCP connection's status  in the DLL, it is important to do this in LV.
Faure
Cape Town.
Western Cape,
South Africa
(7,427 Views)
Can you give me more details on what you are trying to do because I am little confused. You mentioned checking status of TCP connection, I am not sure what you mean there? Also, you mentioned editing a .NET DLL file within LV, which is possible.
Give me the big picture, and hopefully I can lead you the right way.
(7,416 Views)
Hi
Coming from C#, let me explain how the DLL works.
My hardware includes 2 Rabbits (MCU from RabbitSemiconductors), each of them running a TCPIP Server-based app.
Then I have 7 Harps (Cyclotron current measurement equipment), all housed with the 2 Rabbits, one serving the X-plane and the other the Y-Plane.
The Rabbits can switch between each Harp via a multiplexer.
Now the .NET DLL creates 2 TCPIP connections, one per Rabbit.
Then it creates the Harp classes, which will be 7. They are then linked to the socket connections.
When the DLL is called to create a Harp, it checks to see if there is 2 valid connections and if not , creates them, else it uses the existing connections.
We have written a working system using this .NET DLL inside LV. Now they want us to rewrite this functionality using LV's native TCPIP classes.
I have subsequently read about GOOP and general OOP programming in LV, hoping to somehow get a similar class hierarchy in LV.
But my inexperience in basic LV knowledge has been frustrating as I don't know how the check if a TCPIP connection exist and running or not.
I have attached the VI's and subVI's.
You can see in Test_Rabbit2.vi I'm calling subvi "Harp_Init2.vi", who calls subvi "LVRabbit.vi".
The problem is that I need to call "Harp_Init2.vi" seven times, which will call "LVRabbit" seven times. Therefore I need to check if the 'TCP Open connection' is already opened or not.
I hope this info will be sufficient to explain to you my problem.
Thanks.
Amien.
Cape Town
Faure
Cape Town.
Western Cape,
South Africa
(7,414 Views)
Hey,
I believe you could try testing whether there is a connection by checking the error cluster on an open TCP  connection, no timeout error  means that the device is available at that IP address.
I hope this helps!
(7,386 Views)
