Industrial Communications
Thermocouple installation on REM-11120
I am using REM-11120 on etherCAT for temperature measurements. Following the user guide when I connect a thermocouple and write a sample VI, it shows a constant value (-32764), which never changes.
I followed a below instructions to write a VI for REM-11120
http://zone.ni.com/reference/en-XX/help/372626P-01/indcomecat/scale/#instance3
Please guide me in this regard.
Thanks in advance!
(2,944 Views)
Did you deploy the EtherCAT master and change the Scan Engine's mode to Active?
Did you try to change the temperature and check if the value showed (-32764) changes?
Can you provide your LabVIEW project here?
(2,921 Views)
Thanks for your reply!
I followed the given example for REM-11120, and it started working!
Cheers!
(2,909 Views)
