Industrial Communications
XNET Read Transmitted Messages CAN (J1939)
I need to read my transmitted frames in my Frame In Stream session. When I set "Interface:Echo Transmit?", LabVIEW returns error: (Error -1074384860) NI-XNET: (Hex 0xBFF63024) You have configured a property that conflicts with the current mode of the session.What property might be in conflict?
(5,618 Views)
I'm pretty sure your problem is that you want the Frame Out Stream to be set to echo, not Frame In.  You can't echo a received frame, you must echo a transmitted one.  I believe you can also echo Signal out sessions, or individual frames with the echo boolean on the frame to be sent.
(5,579 Views)
I got the same problem. I am sure I‘m using frame in stream.
(3,543 Views)
As mentioned by Hooovahh, the EchoTransmit? property is for the output session.
https://tmesystems.net/
(3,511 Views)
What version of LabVIEW are you using? In LV2020, I remember that two of the bools in the CAN definition cluster were mixed up... so if you set the Echo bool you were actually setting some other property. I can't remember which property at the moment and my code that fixed it is now deleted since it if fixed in LV2023.
(3,381 Views)
