Industrial Communications
XNET problem -1074384878
In a VI I use XNET create session, but i have this error "-1074384878"
Is someone have any idea??
(4,679 Views)
Alex,
I think this post would be better suited for Automotive and Embedded Networks forums . You will find lot more NI-XNET and NI-CAN users there.
Anyway, I entered your error into LabVIEW Explain Error window(In LabVIEW click Help>> Explain Error) and i basically got same explanation as in your screenshot:
Error -1074384878 occurred at an unidentified location
Possible reason(s):
NI-XNET: (Hex 0xBFF63012) The maximum number of frames has been exceeded. Solution: Use fewer frames in your sessions.
Have you tried given suggestion? If it didnt help, post to forum I linked above.
Miro T.
(4,667 Views)
