Industrial Communications
cRIO PB compatibility with cRIO 9047
I am trying to use the cRIO PB in my cRIO 9047.  It is installed in slot 1 and slot 2 is empty.  I can also see the device in NI MAX and perform all the necessary steps to configure it in NI VISA.  It is also discoverable in Configurator III.  However, when I attempt to load the configuration to the hardware, it displays the warning regarding resetting the FPGA I/O 3 times and then displays a message stating it can't configure the hardware.
Is the cRIO PB truly only compatible with the cRIO 91xx expansion chassis series or is there another way to use it with an actual cRIO standalone system like the 9047?
(1,867 Views)
See the attached message I get when I try and add my target to the PROFIBUS example project.
I am using LabView 17 sp1 with the cRIO-9047.
(1,855 Views)
