Industrial Communications
cRIO and SCP
We are looking at purchasing the cRIO-9047.  But before I do, does it support SCP file transferring protocol?  I'm trying to transfer files from the compactrio to a modem so it can do things with it.
Please advise.  Thanks.
(3,352 Views)
Hey TraderJoe,
The cRIO-9047 (and the rest of the 904x family) all run Linux RT. There's an scp utility in Linux you could use. It's all through the console. It's pretty well documented online (e.g. here and here). It has commands for pull and push actions. Additionally, you can run console commands from LabVIEW Real-Time using the System Exec VI.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,322 Views)
