11-13-2006 03:32 AM
11-16-2006 07:36 AM
11-16-2006 08:25 AM
Hoi Wouter.
Ok, I can use a card and the OPC Server for that card and use Datasocket to communicate. But is it not easier then to use a card which has LabView Vi's for it like the comsoft. And about those GSD files i've got, can I link those to Datasocket OPC, or to the dedicated Vi's? I've read the application note aroundthe Applicom, and there the device is an S7 PLC, But where do you get the device and protocol parameters for the device you use? are these in those GSD files? for me al this is still a little bit dark..
Greetings
Yvan
Bosal/Belgium
11-16-2007 07:41 AM
You can use siemen's simatic net s/w. The gsd file for the device can be imported to this s/w and configuration of i/o's can be done. In Labview, you can access the registers of the device through data sockets.
Hope this helps
