Industrial Communications
connecting a plc without opc server
hi, can i connect a plc to labview 7.1 (to send and read data) without an opc server, using just an rs232 cable from plc to pc.
(11,939 Views)
syd_b,
there is no general answer to this question. Some PLCs use simple serial protocols that can be implemented in LabVIEW without difficulty. E. g. if your PLC talks Modbus, you can download a Modbus library from ni.com. Things become much easier with an existing library or instrument driver. Implementing a complex protocol by yourself is possible, but it might be cumbersome and sometimes it's hard to get the full documentation. Which PLC and protocol do you have in mind?
Kind regards,
Jochen Klier
(11,938 Views)
 hi, the protocol is serial(rs232) and it´s an allen bradley plc. and i don´t want to use opc server, i have to use a direct serial communication.
If it´s possible, what do i have to use in labview to read and write data. an example will be awesome.
thanks
(11,929 Views)
syd_b,
RS232 is just the physical interface, but it says nothing about the communication protocol. Allen Bradley PLCs use several serial protocols, e. g. the DF-1 protocol. You can either try to implement the protocol by yourself by using VISA calls (good documentation is required) or you can purchase a library. NI doesn't offer an Allen-Bradley library for LabVIEW, but I have found a vendor with a quick Google search.
Jochen
(11,924 Views)
hi, the protocol is DF1. I have to use VISA calls to read and write?
Sorry, but i´m really new in this topic.
thanks
(11,910 Views)
Accepted by topic author syd_b
Hi syd_b,
yes, VISA read and write operations are basically the functions you have to use. Please refer to shipping examples for serial communication. Still I don't have a clue how complex the DF-1 protocol is to implement. It might be a much better deal to purchase an OPC server or a ready to use library instead of reinventing the wheel, but of course that depends on your personal circumstances.
Jochen
(11,892 Views)
hi,
thanks for all help, it was a very useful information.
(11,884 Views)
