Industrial Communications
ethercat
I have a problem when trying to configure communication between cRIO 9030 and yaskawa SGD7S servo drive through etherCAT.
My project has detected my servo drive as a slave in cRIO master.
I choose unbundel axis in axis manager....
when I deplloy all, there is no problem.
but when I try to running in a simple program... it allways has an error.
I also try interractive test panel. it also not working...
(4,619 Views)
Hello ade45,
What error message are you seeing whenever you run your program?
Gabby
National Instruments Applications Engineer
(4,583 Views)
I think your slave uses CANopen over ethercat (CoE), for what i know NI does not support it.
I had simaler isues with a similar drive, it turns out to be also CoE instead of true Ethercat.
I never did manage to get it working. So i think your drive is not compatable.
(4,333 Views)
