Industrial Communications
getting started with NI usb-8473 and CANbus
I am not ready for current project.
Before I used third paty  labview support.
Message 11 of 19
(6,169 Views)
go to "help" ----> "find eamples". then search for "can transmit" and "can recieve" vi's. you need both open and running together to transmit and view a can frame.
Message 12 of 19
(6,164 Views)
USB-8473 is NOT used with X-NET.
You need NI-CAN driver for a USB-8473.
I think this is the reason you can't find the example
Message 13 of 19
(6,160 Views)
Yes. you are ight. Xnet not work on USB-8473.
I use Frame API on it, work fine now. Thank you very much.
by the way labview2015 not work with the CAN function icon.
I am useing labview2013 for it.
Message 14 of 19
(6,142 Views)
HI,I am using can-8473 too,and i have gotten a problem that my product's boud rate is 100k,but the smallist boud rate of can-8473 is 125k,Is the reason that i cannot communicate with the product?
Message 15 of 19
(5,320 Views)
QIAN_YQ
Any NI-CAN or X-NET question is better suited for Automotve and Embedded Network Forum.
http://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
You will find more people who work with these products there.
To your question, 100k baud rate is pretty small I would advise to look over the user manual of your device and double-check if the device is suited for High Speed CAN or Low Speed CAN network. Again posting this info to the forum I linked above will get you more help.
Message 16 of 19
(5,312 Views)
'Hi
I am using USB 6353 and USB 8473 to transmit the CAN signal.
When I open the CAN Transmit-Periodic .VI example and run it , am getting the "NI-CAN: (Hex 0xBFF6210D) error".
Can anyone help me to solve this issue.
Thanks.
Message 17 of 19
(3,657 Views)
What is your product rate?
You have to same rate as your product.
You can use scope to measure CAN signal.
Message 18 of 19
(3,340 Views)
I could not find the error code 0xBFF6210D on ni.com.
I think your hardware connection maybe missing 120 Ohm resistor.
Message 19 of 19
(3,337 Views)
