Industrial Communications
i am using the PCI1500PFB in WIN NT Service Pack 3, with a PLC Siemens S7 CPU 222, interface EM 277 Profibus DP.
i don't have problem for the configuration with PcConf (Aplicom).
my problem is with the server explorer (NI), i dont creating a workgroup.
i want using the PCI1500PFB for the network monitoring of PROFIBUS DP, in labview.
do you have a completed example ? i need a completed example for configuriting a workgroup in (Server Explorer).
I used the labview, WinNt SP(3),PCI1500PFB, PLC siemens CPU 222 with a card interface EM 277.
(8,853 Views)
There are documents that help you set up these environments. They are located in the Developer Zone from our web site.
Follow:
RESOURCE LIBRARY > INDUSTRIAL NETWORKS > PROFIBUS
(8,853 Views)
