Industrial Communications
invertek and modbus
Hi people
Sorry for almost duplicate, but here I use a visa com port to comunicate with drive
http://forums.ni.com/t5/Industrial-Communications/invertek-drive-modbus-communication/m-p/3308419/hi...
But starts to come complicate to translate the string to decimal numbers.
So there must be a Modbus example that we can input register numbers to get data from driver.
In attach there is a png that tell me the data format to send, a vi that works (with precious hel of Kees) with visa and the modbus drive manual.
So could you please tell me if a modbus (i ha installed the add in)  works easier than my example. The problem is there some register numbers could be for read or write deppends if we use a 03 or 06 before.
I am sorry if I duplicate post but I need to get data from drive to start a research and of course my academic knowledge is not enought to understand bytes and bits as the manual explain.
Best
cpalka
(4,086 Views)
Have a look at the display option of the data in my VI. The data is presented in HEX
You must understand that you are sending a string. The way how this data of that string is presented does not change the data.
Kees
(4,082 Views)
The interaction between LabVIEW and modbus is well documented on NI community, find those two samples :
1) http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/MODBUS-RTU-multiple-write-amp-read-NI-VISA/td...
2) https://decibel.ni.com/content/thread/21786
And NI provide also some good tips : https://decibel.ni.com/content/docs/DOC-30140
Dasso
(4,064 Views)
Many Thanks Dasso
Seems that is what I mean.
Tomorrow I will give news.
Best
cpalka
(4,056 Views)
