Industrial Communications
modbus rs485
Erfan,
Your message is more likely to be seen if you post it as a new topic.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 11 of 13
(3,144 Views)
Dear jack,
Ensure that to add the modbus library to your labview installation. Download it from the link below.
http://ftp.ni.com/pub/devzone/epd/nimodbus121.zip
Also ensure that you have created the CRC correctly. If you dont know about the CRC creation. Use the below link and download the vi and use it as a subvi in your program.
http://ftp.ni.com/pub/devzone/epd/crc-16.vi
Always follow the RTU-Modbus manual of the PID-500-x-x-04, which you can get  from the customer care of Selec.
With regards,
Jeyadheepan K. M
Message 12 of 13
(2,853 Views)
I'd personally suggest using the newer modbus library here, but I'm biased:
https://decibel.ni.com/content/docs/DOC-30140
You shouldn't really need to touch visa (or the crc) except potentially to set your 485 port to the appropriate wire mode (2-wire, 4-wire).
From the original post it sounds like visa is not installed, simple as that. Confirm you've downloaded and installed ni-serial from ni.com/downloads
Message 13 of 13
(2,817 Views)
