Industrial Communications
read in signals from a usb 6212 in more then one computer
I have a NI-USB 6212 to read in signals from a industrial proces in the computer. This computer has also a touchscreen so workers can select a reason why the proces is stoped. Now the problem is that this has to happen at two places so with a another compter and touchscreen plus on a another computer has to monitor on a big screen al the procesvariabels. I want to do this al with LABview. What is the best way to do this?
Kind regards,
(7,187 Views)
Accepted by topic author fille
fille,
if the signals that are acquired by the 6212 are not too fast, you could write the acquired data to network published shared variables. If your second PC has a network connection to the first one, you will be able to access these shared variables there.
Kind regards,
Jochen Klier
(7,186 Views)
Where can i find how you made a I/O from the USB 6212 to a network shared variable an can read it in another computer that is connect to a LAN-network.
Kind regards
(7,145 Views)
