Industrial Communications
troubles with rs 485 on Labview.
Hi guys, so I trying to read some data of a meter ( Mult-K kron ), from the rs 485. I haven used the software of kron, and its works. But now I want read the same data on LabView and I cant read nothing. Sorry, I new on this. If somebody can help.
Best regards !
(6,259 Views)
If the SW of Kron works OK you know that the hardware link.
Tell us what you used in LabVIEW. What is the protocol of the meter ?
Kees
(6,226 Views)
Hi, tks by the answer. The protocol is modbus RTU (rs-485).
I trying use this:
And I used a converter rs485 to USB.
(6,224 Views)
You don't write anything. If you want data from a ModBus slave you first have to write data.
Why don't you use the ModBus Library from NI ?
(6,219 Views)
Hi, sorry about that. So I change to MB lib.
e use this :
About write, how I know what I need write to receive the correct data ? I trying to search this in the manual, but I dont find nothing. Sorry, is the first time I'm doing this.
(6,214 Views)
Accepted by topic author betows
Try to use the examples available in Modbus Library, and read a tutorial about Modbus in LabVIEW.
ModBus Protocol Reference Guide
https://www.ni.com/en/shop/labview/introduction-to-modbus-using-labview.html
Modbus Library
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
I hope it can help you.
Lincoln
(6,199 Views)
