0xBFFF0015 - Agilent N9010A - TCPIP Driver Issue
Im attempting to run the example VIs from the 4.13 driver version for the N9010A on my Mac. I've been able to set up the N9010A on NI-VISA as seen below. (I'm running Labview 13)
I've also been able to read and write to it using nivisaic:
But as you see from above it still times out even though I recieve valid data.
I get the same message when im attempting to run the examples. I also attempted to add Termination Character support but it makes no difference.
Is there something I'm doing wrong? Or something obvious that i'm missing?
Jared
(4,479 Views)
Are you able verify that the N9010A works with another computer?  It seems like this would be a driver related issues.  What specific drivers did you install?
(4,463 Views)
