12-21-2013 06:35 AM
I'm trying to control an Angilent 33522B by PXI-8106 running RT system.
Firstly, it can be connected and controled properlly by normal computer.
Secondly, it canbe connected and validated by an address like this:
However, when using the driver provided by agilent d move it to RT sessions, then it doesn't work......
Then I try Visa test panal, Query *IDN?\n
the result will still give me the right response, but also an Error.
Read Operation Error
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
Now, go back to the program using this instrument, run it. The computer will then seem to wait the 33522 to response.
Has anyone ever encountered this kind of problem and can helllllllp me?
THX
Lorry Liu
Tianjin University, China
12-31-2013 10:29 AM
You do not mention what sort of driver from Agilent you are trying to use. It sounds like it might simply not be compatible with the RS operating system.
The VISA timeout is probably happening because you have not configured the termination character correctly.
