1 Want command to check whether SR830 lock-in amplifier is overloaded or not
Actually I want to know the coding for detecting whether the SR830 lock-in amplifier is overloaded or not. I have searched it in SR830 manual but can not find it. Can anyone help me regarding this ?
(4,890 Views)
For something this specific, you should ask the vendor - http://www.thinksrs.com
(4,883 Views)
That information is returned in the LIA status byte (pg 5-23 of the manual). You can use the LIAS? command to query that byte, or if you want, you can set the instrument up to generate a device request when one of the overload bits flips and then monitor for the SRQ.
(4,835 Views)
