180100-02 Rev G GPIB-PC hardware settings
I have a ASSY180100-02 Rev G GPIB-PC card and I need to know how to configure the hardware to setup the base i/o address, dma channel, IRQ.  I can only find docs for GPIB-PCII/IIA.
(3,450 Views)
Hi Nostaro,
The current GPIB card you are asking about is an older card and due to its age documentation for it can be rather hard to find.  If you would like to stay up to date on drivers and documentation I would recommend upgrading to a newer GPIB board.
One question regarding your current board, which OS are you using? I found another sheet that explains the compatibility between OS’s, and I was hoping you could take a look at it, and verify that it is correct.
http://zone.ni.com/devzone/cda/tut/p/id/5326
Andy L.
(3,426 Views)
