2mV/V Load cell output measurement with NI 9218
I am using two full bridge buster load cells of 0.5kN and 1kN both of which give 2mV/V analog output. I am trying to measure the output of the load cells using NI 9218 analog input module, will need additional amplifier in order the get proper reading?
(903 Views)
As per my understanding, 9218 can measure up to 22mV/V ratiometric value in bridge configuration and given your sensor is only 2mV/V, it is compatible.
I will wait for others to confirm.
Santhosh
Soliton Technologies
(867 Views)
