34410a gpib response time
Does anyone have a 34410a gpib response time using LV and a USB to GPIB HS controller?
(4,106 Views)
Hello jrconsulting,
Attached is an NI-SPY file of the "Agilent 34401a read multiple measurements.vi" example ran with a USB-GPIB-HS.  You should find all the information you need there.
O. Proulx
www.ni.com/support
(4,081 Views)
How do I open this file?
(4,076 Views)
you should be able to open it if NI-SPY is installed on your computer.  NI-SPY is installed with NI-VISA.  I've attached a screenshot of the file in case you do not have this software.
O. Proulx
www.ni.com/support
(4,074 Views)
