4 wire sensing erratic behavior (LabView & Keithley 2400)
I am currently attempting to take a 4 wire measurement sourcing current with a Keithley 2400. However I keep having very erratic measurements. I am currently measuring a 150.5nm Silver thin film. I am worried that the impedance of the device may not be high enough because I keep reaching compliance or the current is leaking out of the probes. When it is in the 2 wire mode the program produces expected values, but in the 4 wire it is difficult to obtain a steady reading. Please help.
(4,888 Views)
(4,874 Views)
Are you on the 4 wire Sensing Mode? Get there by pressing " Config" >> "Ohm (symbol) >> "Sense Mode" >> 4Wire.
Make a hand measurement before letting LabVIEW take over. Is the arrangement of probes right?
Keithley has good support so I would suggest giving them a call..
Gautham
(4,805 Views)
