488.2 DOS Support in Windows 10 32-bit
We have a PC in our production environment that was running Windows 7 32-bit and has been upgraded to Windows 10 32-bit.  The NI488.2 driver in NI Max has DOS Support enabled because there is a DOS application that we need to run on the computer that uses GPIB.  Upon trying to enable in after upgrading to Windows 10 32-bit, the program complains that the Config.nt file needs a device line pointing to gpib-nt.com.  I updated the file to add the line and I still cannot enable DOS support.
Anybody know why I cannot do this and how can this be corrected?
(2,864 Views)
Apparently uninstalling and reinstalling the NI drivers solved the problem.
(2,814 Views)
The steps he took are:
uninstall, reboot, sfc /scannow, reboot, the reinstall
(2,777 Views)
