54522A Oscilloscope
i am trying to use a 54522A oscilloscope on Lab view.
i grabbed the driver below and tried to use that program to read the oscilloscope on the computer through a GBIP connection. i ended up getting this warning:
the driver is located here.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1120
can anyone tell me what this is and if you can what i can do to fix this? (i am very unexperienced with labview this is my fourth or fifth time doing it)
(3,884 Views)
it says
Load and Save Warning List
History
1/28/2011 4:16:44 PM ==Loaded HP 5452XA Read Normal-Avg Waveform.vi
details for Top-Level Item
   Loaded from path: C:\Documents and Settings\Tom Colbert\Local Settings\Temp\Temporary Directiory 2 for
   hp5452xa.zip\HP5452XA.LLB\HP5452XA Read Normal-Avg Waveform.vi
types     Items (-these are the tabs)
(under types)
Warning Types
Dependency loaded from new path (2 warnings affecting 2 callers)
Details
Expected Dependecny Path                                                              New Dependency Path
<instrlib>:\hp5452xa\HP545XXA.LLB\HP545XXA Recieve Message.vi    C:\Documents
        andSettings\Tom Colbert\Desktop\drivers
        for research\HP545
 Affected Callers
 C:\Documents and Settings\TomColbert\Local Settings\Temp\Temporary Directory 2 for hp5452xa.zip\HP5452XA.LLB\HP5452XA R
(3,878 Views)
Install it to the correct location. There are instructions on the download page. The expected path is even shown on the screen you posted.
(3,873 Views)
thank you.
(3,868 Views)
