64bit Linux driver support
Are there any plans for 64bit Linux driver support?
(4,798 Views)
Unfortunately, National Instruments currently doesn't have plans to support 64-bit Linux platforms (See this link). You can find more information about Linux support at ni.com/linux. Hope this helps. Thanks!
Ebele O.
(4,780 Views)
dear national instruments product management,
adding:
a) support for 64-bit kernels
and
b) a "kit" version of your driver that is designed to be adapted to distributions that you do not support.
...to ni-daqmx would be a really nice thing that you could do for your customers.  please think about it!
thanks!
--adam
ps.  those who would find these two things useful, please add a reply to this thread so that it might happen some day.  thanks!
search fodder: 64bit 64-bit 64 bit linux daqmx ni-daqmx ubuntu kubuntu dapper edgy debian sarge gentoo
(4,679 Views)
...or better yet drop NI and go with a competitor that will support 64bit. Thank you INES. Forward thinking? Wake up NI.
(4,670 Views)
You get the source for NI-KAL, this is essentially a "kit" that allows you to port to whatever distribution you want (32-bit, of course). NI has a few standard distributions that we test with, but that doesn't in any way prevent you from your heart's desire (except 64-bit, of course).
(4,664 Views)
The thread is about 64bit Linux support, so I'm not sure what your point is.
(4,660 Views)
I was responding to:
I probably should have quoted that in my original reply. Yes, this thread is about 64-bit support, but I felt the need to respond to the non-64-bit section to clarify the support.
(4,657 Views)
