6632A IVI Driver
Does anybody know if  there is IVI driver for HP 6632A that will work with Labview.
I know there is the standard driver but could not found an IVI driver.
Thank you.
Elik
(3,985 Views)
I could not find one from NI or Agilent. The instrument is so old that I'm not even sure IVI existed back then.
If you plan to work a lot with IVI, it would be worthwhile to buy CVI. Then you could edit any existing ones that you find have bugs or you can create your own.
(3,981 Views)
Thanks. I will follow your advice.
Elik
(3,967 Views)
