7061 solartron schlumberger driver
Could any one help me out with this. I have "7061 system voltmeter Solartron Schlumberger Phase Analyser" which  I want to interact with Labview 8.0 Labview, I don't have the driver and I need it to communicate with Labview.
Innocent.
(5,069 Views)
Did you try searching the Instrument Driver Network? You would have found this.
Even without a driver, you should be able to communicate with it. You would, of course, need the programming manual.
(5,059 Views)
Hi, Thanks for this..I have been able to communicate. The issue was with my device not fost set to GPIB mode.
Thanks for this and the link to the VI's for the Instrument.
(5,013 Views)
Hi All,
Still on a mess. I am relatively new to labview. The VI I got online for 7061 solartron can acquire data but I want the data to be continuouslybe logged to a file. Also if I set the analyzer to acquire multiple channel data would I be able to separate the acquired data and log them separatly in a spreadsheet.
Innocent.
(4,941 Views)
Hello uwo,
One suggestion I would have it to use the Write to Measurement File Express VI. This is not an out of the box solution but it would require minimal programming in order to get it to work. Hope this helps.
Best Regards,
Adam G
(4,926 Views)
