816x driver/wrapper
@Dennis_Knutson wrote:
I don't recall the old converter giving an option for serial but I suspect that it added an option to set the com port and to configure the termination character. Look at the 34401 driver and add the code in that to the initialize function in the Agilent driver before the Call Library Function Node.
I'm not sure if it was the converter itself. I think the steps were explained as Solution wizard-> Instrument driver wizard and then came up with the options when you found the driver. I also don't remember any call library function nodes (I think the dll wasn't written in c, but LabWindows or something), but get what you mean (there is blocks designating calls to the dlls functions) and it sounds like a good idea. I'll give it a try on Moday
Message 11 of 12
(962 Views)
Just fyi, LabWindows is an ANSI C compiler.
Message 12 of 12
(959 Views)
