9870 in Scan Mode on NI9146
My ports show in MAX, but are not available in my lvproj chasis using Scan Mode?
All other modules work as expected.  I have used this module in scan mode in another chasis, but the 9146 is new to me.
I made a serial loopback connector and ran a serial loopback test as attached.
Any help and insight is appreciated!
- P
(5,628 Views)
Hi P,
As of LabVIEW 2010 and later, we do support scan mode for your 9870 device. However you will need to install support separately using a custom software installation for NI-Serial and 9870 and 9871 Scan Engine Support. I've linked a more detailed explanation of this issue in the KnowledgeBase below:
Using the NI 987X Modules in Scan Mode: http://digital.ni.com/public.nsf/allkb/16989C708E5AF2C1862578A90067D9DC?OpenDocument
I hope this helps!
Anna L
(5,599 Views)
I already have this installed and running latest all drivers. See attached pics in 1st post showing MAX and lvproj
(5,583 Views)
Accepted by topic author Stranman
I now have it working with a little trial and error.
Looks like "NI VISA Server" is required on the target to select the VISA resource to read.
(5,553 Views)
