ADSR status register
I am trying to interface TNT4882 chip with STM32F103. I have been following the steps mentioned in ESP-488TL Software referance manual.
But after chip init, when i try to write a GPIB address with talk only or listen only. I can't see any change in ADSR status registed.
The register status remain unchanged at 64 in all 3 conditions mentioned below
   1. Before chip init
   2. After chip init
   3. After changin primary address with listen only
   4. After changin primary address with talk only.
What could be the possible cause for this problem.
Expecting your assistance ASAP
Thanks in advance
With regards,
Jerin George
(4,145 Views)
The problem is solved
(4,117 Views)
我有个跟你一样的问题
能否告知你是如何解决问题的?
非常感谢
(4,019 Views)
Could you tell me how did you solve the problem?I have the identical problem
(3,799 Views)
