AGILENT 54622A lay out in labview
Does anybody has any lay-out I can use in Labview to simule the Agilent 54622A device (or other Agilent devices) ?
just the layout , I will connect buttons & booleans for simulation.
We use an GPIB bus
tnx,
K
(3,562 Views)
Are you trying to duplicate the exact physical appearance of the the scope and all of it's menus or just trying to replicate the functionality. Doing an exact physical representation is a fairly rare and difficult task while replicating the functionality is a common and easy task.
(3,558 Views)
I'm trying to replicate the functionality.
With other words, to do the same with this application like in real life. If I touch a button to change the voltage the application reads the value from the real scope and I program this.
I just need the lay out of this scope or other scopes (Agilent types)
(3,556 Views)
There are drivers for that scope available here. For other instruments, go to the main Instrument Driver Network page where you will also find links on what an instrument driver is and how to use one. You can also search for a driver by going to Tools>Instrumentation>Find Instrument Drivers.
Very few of the drivers has a front panel that duplicates the layout of an actual instrument. That is why I asked if you needed to duplicate or just replicate the functionality.
(3,552 Views)
