ASIC interfacing
Hi Pat. Thanks again.. how about the tnt4882 ASIC?
Message 11 of 18
(2,540 Views)
Unfortunately, no, the TNT4882 ASIC is not suited for the application as discussed.  I apologize for not addressing that directly in my previous post.
Patrick
CLA
Message 12 of 18
(2,519 Views)
Hi Pat,
Last question, But using the TNT4882 IC, can I tap on the current Tester and Handler setup and monitor the on going communication on them (assuming my programming is correct)
Message 13 of 18
(2,512 Views)
Yes, but the TNT will handshake the data.
Message 14 of 18
(2,508 Views)
Hi GPIB_Guru,
Thanks, so if the data is handshaked... assuming the tester send data to the handler. but since we have a tapped device which is the TNT circuit both the handler and tester will recieved the data? no interference will happen. Smooth operations?
Message 15 of 18
(2,506 Views)
I mean the Tapping circuit and the handler will recieve the data without interference?
Message 16 of 18
(2,501 Views)
I don't know what you mean by no interference, but the TNT WILL handshake the data. It is not a logic analyzer. It is not capable of just reading the data w/o handshaking. You can snoop, but you can not do it the TNT like you can a logic analyzer (which is basically what the analyzer board is).
You have two options:
1) Use the TNT and save lots of money and deal with the fact that it will be connected to the bus
2) Spend more money for a logic analyzer to snoop the bus w/o interference.
Message 17 of 18
(2,497 Views)
thanks, Lastly
if the data is sent by the tester and handshaked by either the tapping circuit or the Handler will the data be both recieved by the handler and tapping circuit?
Message 18 of 18
(2,495 Views)
