ASRL Number in MAX differ from COM Number in
I have install the external "PCI 8S Serial card RS-232" (Model EX-41098-2 from EXSYS). In Windows Device Manager ports for this card named from COM1 to COM8 (see screenshot). In NI MAX all ports have a plausible assignment except for COM4. This will assign to ASRL9 and not to ASRL4 (see screenshot).
I have verify the port assignment in Agilent-IO-Tool. Here is COM4 assigned to ASRL4 (see screenshot).
I didn't find a way to change ASRL number in MAX. Has anybody an idea, what the reason of that assignment?  Thank you for help.
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(5,777 Views)
Its likely that some registry entery for serenum or a dependant HKEY is reserving asrl4 for some other known (to your system) Plug-n-Play device.  Since MAX won't go unreserving HKEY enteries.  Agilient IO is not as pollite and can be used to create a conflict like you describe
VISA won't care about anything other than the Alias.
(5,750 Views)
