AV Power PA 4400A GPIB drive
Hi all!
I'm needing to make some measurements with the AV Power PA 4400A power analyzer, and I would know if there is someone that has already developed the Labview drive for this instrument and could share information.
Thanks a lot!
Dráusio
(3,353 Views)
Hi Drausio,
I searched through our instrument driver database at ni.com/idnet, but I wan't able to find this device or even this manufacturer.  Our R&D department maintains a list of requests for instument drivers to determine where there development effors can be best applies.  If you can't find a driver on our website, it is always helpful to submit a request for a driver at ni.com/idnet.
Also keep in mind that an instrument driver is not required to communicate with your device.  If you have the users manual for the instrument and the commands it uses, you can use the NI-488.2 or NI-VISA APIs directly.
(3,333 Views)
