 Kambra
			Kambra
		05-19-2014
		08:29 AM
 - last edited on
		02-27-2025
		09:48 AM
 by
		 Content Cleaner
			Content Cleaner
Hello there!
I have a small problem using the following modbus library for LabView8.6:
After I have started the Slave Demon it takes about 30 - 50 seconds for the first values (send via TCP/IP) to arrive. I have a Graph that plots all the18 read values for me and it always takes a long time to see them jump fom 0 to another value. Afterwards there remains a delay of about 30 seconds regarding how current the shown values are.
I can't post the VI here because it uses a lot of SubVIs which would make it not runable anyway. However, I already checked the Modbus Salve Example VI and there I have the same delay as in my own programm.
Anyone got any ideas?
Thanks in advance and kind regards,
Kamil
Solved! Go to Solution.
05-20-2014 03:45 AM
Problem solved. It was the device (a data logger) that was acting so slow in sending the data while it was acting as the master. I changed it now to be the slave and read its holding registers. This way the values arrive "immediatelly".
