About Instrument VI
I am using RMX 4005 to measure the fuel cell voltage and current. I am using one of the example VI from the library. I am trying to use this example VI in different VI where I have USB DAQ 6001 connected with pressure and flow sensors but I am getting errors. could you please help me how can I modify this example VI and get all readings from USB DAQ and RMX 4005 in single VI.
Thank you
(1,825 Views)
please attach your program and vi's so that we can see what is a problem.
Shooting in the dark seldom generates a solution.
greetings from the Netherlands
(1,783 Views)
As well as the code, what errors are you seeing?
(1,776 Views)
Thanks it worked.
(1,727 Views)
