Access to locked buffer while DMA active: viMoveIn32 or viMapAddress?
Hi all,
I'm using double-buffering DMA to transfer data into half of a locked buffer I allocated using viMemAlloc(...)
I want to process the first block of DMA data while the other half is being DMA'd in.
The tutorial (http://zone.ni.com/devzone/cda/tut/p/id/3251) suggests that I should be copying the whole buffer out to user memory using viMoveIn32(..., VI_PXI_ALLOC_SPACE, ...)
It seems like an unnecessary step when I can simply get a pointer to the buffer using viMapAddress.
Having said that, it seems that if I use the viMapAddress method once every few million DMA transfers my PC crashes with a blue screen of death.
Any suggestion why that should be happening?
Carlo
(3,352 Views)
Hello Carlo,
Can you please provide some more information regarding the versions software that you are using and the hardware that makes up your system.
Kind regards,
Daniel T
Account Manager
National Instruments UK & Ireland
(3,337 Views)
Hi Daniel,
I'm using NI-VISA 4.6, our system uses a PLX 9056 device to implement the PCI interface and we DMA data by having the 9056 take control of the bus and write to a locked buffer as suggested in the tutorial above.
Looking better at what the code now does,I copied to a user buffer before a new DMA transaction is kicked off while before I had concurrent access to the locked buffer from the next DMA transaction and from the user threads (using a pointer provided by viMapAddress).
Carlo
(3,334 Views)
