Acquiring data from a ccd linear array using LabVIEW
I would like to control a CCD linear array using LabVIEW. I would appreciate some help regarding which components I would have to buy, and how should I go about it. I don't know which CCD will be compatible with LabVIEW so I haven't bought one until now.
Thank you
(3,783 Views)
You probably need high speed digital IO and preferably an FPGA card for controlling the ccd lines and doing the input.
Especially the ADC needs to be fast.
greetings from the Netherlands
(3,782 Views)
Thank you, In my lab, I have SMX 160M (http://www.sumix.com/products/cameras/smx-160m.html) although I am not sure if I can use it via LabVIEW. Also I have Prosilica EC1280(http://www.avsupply.com/Prosilica/ec1280.php). I searched whether they can be integrated with LabVIEW but couldn't find relevant information. If possible could you please tell me how can I use them using LabVIEW.
Thank you once again.
(3,780 Views)
